Yeah, my draper leaked straight from the box. Not goodBe interesting to see how you get on with those, mine have started leaking again.![]()
Hey @david173 I have the bottle jack now, it will jack up to 340cm which is more than enough to lift the van. I have a trolley jack rated at 2 tonne, I don't feel confident using it on the van hence the bottle jack purchase.Looking at similar to replace the fisher price jack that comes with the van. Do you mind posting up how you find it? Fitting under van and height for wheel removal etc please?
that would be great thanks!Hey @david173 I have the bottle jack now, it will jack up to 340cm which is more than enough to lift the van. I have a trolley jack rated at 2 tonne, I don't feel confident using it on the van hence the bottle jack purchase.
The bottle jack is rated to 4 tonnes so should be easier to use than the trolley jack.
I am going to test run it this afternoon, will post some pics for you.
Mine... how many Jacks do you have mate?Be interesting to see how you get on with those, mine have started leaking again.![]()
Interested in this! I bought a 2.5 ton trolley from EuroParts! Lost all confidence in it even swapping over my wheels. (So much so, I slipped my local tyre shop a few quid to do them for me!)Hey @david173 I have the bottle jack now, it will jack up to 340cm which is more than enough to lift the van. I have a trolley jack rated at 2 tonne, I don't feel confident using it on the van hence the bottle jack purchase.
hey @JOGInterested in this! I bought a 2.5 ton trolley from EuroParts! Lost all confidence in it even swapping over my wheels. (So much so, I slipped my local tyre shop a few quid to do them for me!)
As you’re on air, I’m sure you’ll find getting the bottle jack in easier though. Can you post picks of where you jack and where you position your axle stands?
Good info - I will check that when I get near my vanhey @JOG
I did have to lift Floyd a small amount to get the jack under but then I was on the lowest setting for driving.
The min height for the bottle jack I have is 180mm, if that helps at all?
Boys comparing their leaky jacks!Easily done mate,
Don’t forget to allow for it going under the van with a flat tyre.Hey @david173 I have the bottle jack now, it will jack up to 340cm which is more than enough to lift the van. I have a trolley jack rated at 2 tonne, I don't feel confident using it on the van hence the bottle jack purchase.
Good thinking! Didn’t consider thatDon’t forget to allow for it going under the van with a flat tyre.
I ended up carrying some aluminum plates to go under the jack and a ply board to drive onto if the tyre is completely flat.
Wise thoughts @DXX,Don’t forget to allow for it going under the van with a flat tyre.
There’s quite a lot of fine tuning as you also have to allow for suspension sag when the weight comes off the wheel.Good thinking! Didn’t consider that
I hope you remember it’s there.Call me paranoid, but had this installed today - hopefully it will make any scumbags just move onto a softer target...
