They look like a good idea and overwhelmingly get 5* reviews, but a number say the phone falls off when driving. If it gets 77% 5* reviews and 2% 1* I generally assume the 2* are none too bright and have used it incorrectly. Let us know who is right, please. Amazon does a 2-pack for £11.99.Simplified my phone connectivity for Apple Car Play. Short Anker braided USB-C lightning cable, and a little vent mounted magnetic phone holder. No more tangle of cable (the short 1ft jobby is just right), the small magnetic vent mount grips to the air vent really well (with soft rubbery feet), and the magnet it comes with can be stuck on the INSIDE of my phone case and is still plenty strong enough to attach to the mount. Quite satisfying getting in the van and just throwing the phone into place
I’ve used https://www.amazon.de/dp/B099WY5FQT for over a year and a half now. Coupled with wireless CarPlay it’s been great, charges the phone and no plugs to fiddle with.Simplified my phone connectivity for Apple Car Play. Short Anker braided USB-C lightning cable, and a little vent mounted magnetic phone holder. No more tangle of cable (the short 1ft jobby is just right), the small magnetic vent mount grips to the air vent really well (with soft rubbery feet), and the magnet it comes with can be stuck on the INSIDE of my phone case and is still plenty strong enough to attach to the mount. Quite satisfying getting in the van and just throwing the phone into place
This place is very dangerous for that I'm finding...Two rollos dodo hex - I have a shuttle and its very quiet inside. Currently got front carpets out for amp wiring etc and had some mats left over from speakers. Thought I would do pedal areas and bulkhead then got carried away. May as well take all the seats and carpet out and see what it does to the echo sound I get when I dont have anything in the very rear load area.
Finding myself jobs I didnt know I was going to do
One of these as one of my ARB bolts sheared when trying to remove it.
Unable to get the stud out so the only option was to replace the whole rear suspension arm.
The ever helpful @Dav-Tec to the rescue as he had a “Spare” lying about.
Not so easy when you need the van on the road within days of starting the job and not having a pillar drill to hand.I would have used a heli-coil to save all the hassle
I jacked mine high enough to successfully drill the old bolt out and re tap it. If it had failed then I had the heli-coil kit at hand to oversize the hole and fit the HC. An hour of faffing!!Not so easy when you need the van on the road within days of starting the job and not having a pillar drill to hand.
Look how shiney and new it looks. . .
i thought they were Grey lol . . . they obviously fade with the Suns UV etc. .
looks even better in Dark Black. . . . . . very nice storage bag too.
the quality feels good. . .
loving the Black KADOR strip as well.
i was umming and arring with @czmate1999 last week at Camperjam about getting a wide BLACK 6-6mm KADOR for my drive away awning.
ended up leaving it - but there is always Busfest right
edit:
yes they OOS, so I've added email notification when back in stock.
the feedback from @Deaky was that they are very good quality, worth the money, and has have lasted 4years +
thats a good enough reference for me........ S+S - take my money.
That looks good. Never seen those before. How does it lock to the pedals? Is it fiddly?And to keep the van a bit safer…View attachment 207796
the Carbon poles have been out of stock for ages. . . .
so gave up and got a set of the regular black ones . . .
to support the Railsail,
used with ground stakes so we dont need all the guy lines. . .
PS, if anyone has or knows anyone that has the carbon S+S poles, let me know.
Black Aluminium Extension Awning Pole
A three-tiered aluminium awning pole which we've designed to be simple, light, hardy and affordable. The perfect companion for our best selling Tarp Awning. To be used in an endless variety of heights from sub 1m all the way to 2.3m allowing for maximum flexibility. ➕ LESS CAMPERVAN MORE ROADTRIP ➕stitchesandsteel.com
View attachment 208288View attachment 208290View attachment 208289
sold out for ever . . . . .
It's probably an illusion created by the angle of the picture but the metal end piece looks a bit short on those and I'd need to knew how long they were before buying.10cm longer, but would these work?
Pole Taraf Tarp Poles Telescoping 11H Hardness 1mm Thickess 2PCS Canopy Adjustable Rods Carbon Fiber Tarp Poles - AliExpress 18
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
If you saw the drive the van is stored on you wouldn’t get under it. My drive is on a slope , isn’t it @Dav-TecI jacked mine high enough to successfully drill the old bolt out and re tap it. If it had failed then I had the heli-coil kit at hand to oversize the hole and fit the HC. An hour of faffing!!
