And a couple of eggs? Tada eggy-bread!!If you're going to use a frying pan, it would seem churlish not to put oil in said pan, no?
A childhood memory right there!
All good suggestions as well, the frying pan is a marvelAnd a couple of eggs? Tada eggy-bread!!
I'd put a lot of money on that power supply being 12v - have a look at the ratings details on it.Obviously needs 240v so need to be on EHU,
And bacon and sausagesIf you're going to use a frying pan, it would seem churlish not to put oil in said pan, no?
Hi roadtripperI'd put a lot of money on that power supply being 12v - have a look at the ratings details on it.
That doesn't mean you should connect it directly the the van electrics as that can actually vary from 11v to 15v, but it does mean you could use a straight forward 12v to 12v regulated power supply. Just check it can provide enough current compared to the original PSU and that the polarity is the same again should be on the ratings info on the PSU as a little diagram (I tend to avoid the generic ones with reversible tips for this reason)
Don't get your hopes up too much with 5g, it's more in built up areas, you need to be within a km or 2 of a mast, if you have line of sight.Three 5g router as my 02 phone speed not great - getting between 100 and 400 mbps with this still to try it out on a site.
Debus are selling some "seconds" of their awnings at £60
Debus Campervan/Caravan Sun Canopy for VW Transporter Transit Vito Bongo Vans | eBay
Allows the side door of a campervan or caravan to stay open and chairs to be left outside in rainy conditions. If there is any faint ink transfer on an individual canopy at all, it is just in one very small (20cm x 8cm max.).www.ebay.co.uk
Just put mine up for the first time and this the extend of my “seconds”
For half price I can live with this mark! Only on the underside, but guess that is the side you see more often
Last time we were away my youngest had Internet but different network (all be it slow) - I had none and as of todays youngster would not share it in case his game went down!Don't get your hopes up too much with 5g, it's more in built up areas, you need to be within a km or 2 of a mast, if you have line of sight.
It's excellent when you do have a good signal, I used Three 5G broadband at home for a couple of years and had 700mbps download speeds, but I was 300m from my mast.
You'll still obviously have 4g internet even if you don't have a 5g signal.
just need to work out how to power the laptop.
I find a belt across the fingers with a big stick works just as well and is more satisfyingBought yesterday received today, the answer to my Jormax top rails neighbour leaning on the fence issues. Instead of electrifying the top rails, I can now welcome folk to lean on the top rails whilst (usually) waiting for a coffee or tea to be prepared! I know there are other ways of doing this with plumbing gear, but this works and is easy, neat enough and good for me! £9.99 for 100 assorted Jubilee clips from the Amazon.
We have no water system in our van, and when we're camping we have been using a collapsible water container which honestly is more than useless. This then cause some minor frustrations and the occasional wet feet!
I was on the hunt for a rigid water container for our upcoming trip to France to try and make things more manageable. That's when I stumbled upon this:
Absolutely perfect for what we need! And the best bit, the tap comes with adapters so that you can fit it to a multitude of different water containers/bottles!
Here you go bud. You have to add the tap seperately but it gives the option lower down!
Hi @Bigsidavies make sure you get the timing belt replaced when the seal is replaced as the oil contaminates the belt causing it to disintegrate causing failure. My friends garage is seeing this happen all the time, even on engine with millage as low as 50k. What’s the mileage on yours?And…….much worse is the amount of oil around the off side which looks like it could be my turn to have the main oil seal done.
I’ll get it booked in at the garage as it’s nearly due a service anyway.
