Where did you buy that from please? I'm still deciding which LED ceiling lights to buy, have my eye on a few but can't make up my mind.A selection of CBE stuff - these will all link back to the portable power generator I am intending to buy. Still need to decide which one and also which LED lights for the ceiling.
I purchased one of these the other day, are you saying that it just melted when he tried to cut it?Bought a VW surf key which turned out to be made of cheese
so the key cutter did me a NON microchip blank FOC
it didn't melt, there is no consistency in the thickness so it cuts through when the second side gets cut so the is no rigidity in the key. The master locksmith who did it advised not to even put it in the lock as it will cost a lot to try and get it removed after it snaps. I message the eBay seller who said he can cut it but i'm not going to send a key or and image of the key to someone who already has my addressI purchased one of these the other day, are you saying that it just melted when he tried to cut it?
Thanks for the response. Looks like Im in the same boat as you.... same ebay seller?it didn't melt, there is no consistency in the thickness so it cuts through when the second side gets cut so the is no rigidity in the key. The master locksmith who did it advised not to even put it in the lock as it will cost a lot to try and get it removed after it snaps. I message the eBay seller who said he can cut it but i'm not going to send a key or and image of the key to someone who already has my address![]()
This what I ended up with so can lock the OEM keys insideThanks for the response. Looks like Im in the same boat as you.... same ebay seller?
What's your address? And can you email me a HD close-up of the key without thatThis what I ended up with so can lock the OEM keys inside
I cut the plastic off and drilled a hole through the end for a super strong split ring so I can wear it round my neck on string (and open the slider with it, post surf)This what I ended up with so can lock the OEM keys inside
The fit on those look excellent, how was getting the skins on?
