Thanks @Dellmassive for the review so far. Interested as I have one on order - several delivery messages but now due Monday hopefully.
I haven't started fitting any of the charging system yet but I have the following ready to go:
Renogy 50A DC-DC with MPPT
BT-2 Bluetooth module (is this needed with the App - I wasn't aware of the App)
200w solar suitcase
2000w 12 v pure SW inverter
Needed to work out what Amp wiring and Fuses I need.
Any news when the Roamer app is getting released ?pt3
The APP
The APP is called "ROAMER BMS" and is in final BETA testing before General release on the play store.
@RoamerBatteries were kind enough to allow me access to the BETA version of the APP and alowed me to show you the APP working.
The APP will be in the play store soon . .
and has NORMAL & DARK mode - it follows the Phones default setting.
my phone is set to DARK mode, so the screen shots below are with the APP in DARK mode.
the start screen is this with the ROAMER logo.
the next page starts an auto scan for BT devices in range.
you can see our battery "11028" is detected.
clicking on the 11028 starts the conection process to the battery.
once connected we get the main page . .
we can see the battery has been shipped with 33% SoC with a nice fuel gauge style meter that shows the Ah remaining.
below that we can see the Charge/Discharge ON blocks.
Below that we see the Voltage, Current, Temperature, and cycle life.
in the shot below you see the battery being charged - @ 25.66A
details of the APP are listed as.
testing wise, we have a 30A Victron IP22 charger - the biggest I've got to hand. - Battery Chargers - How I Did It -
pushing 30A into the battery . .
shown on the battery APP . . .
and confirmed with a clamp meter - Clamp Meters
at 30A its going to take a while to fully charge . . . . . . .
Looking at the thermal they are very good . .
no internal heat build up showing . .
you can see the Victron IP22 running flat out 30A - which is warm,
plus the heat generated in the cables as 30A flowing through them,
View attachment 141724View attachment 141725View attachment 141726
at 1530hrs we was at 33% SoC . .
its now 1800hrs and we are at 64% SOC . . .
There is another details page that is in development . . . this will change in t he final release . .
so this is just a glimpse . .
it shows the:
session data,
Live data,
Cell Voltage,
Battery Protection status display . . .
the SOCC, OTC, FC acronyms will be detailed in the final release paperwork
we can assume from the below that the CHG & DSG are indicating that CHARGE and DISCHARGE are allowed.
END
@RoamerBatteries ... ?Any news when the Roamer app is getting released ?
NiceRoamer arrived this morning!
I'm hoping it'll be published tomorrow, I sent it back to them this morning for two final amendments. Please note that the new app is ONLY for second generation batteries (using the new model VIP BMS). Previous version of the battery used JBD BMS so these batteries will continue to use the existing available apps (Xiaoxiang BMS or equivalent).
Is there a way to make it backwards compatible with Gen 1 batteries ?Ahh this a shame. Do you have any plans to open up the new app for Gen 1 customers? Hope so![]()
Unfortunately not, it only works with the VIP BMS... We'd need to create an entirely new app to work with the Jaibaida BMS. Its a massive investment in time and money so while I'd love to do this to support existing customers, it's just not an option right now. There are a lot of decent apps to use with JBD BMS however as its used in a lot of other LiFePO4 batteries such as Liontron and AOLithium (this one is probably the best of the lot). There is also a second version of Xiaoxiang BMS on the way apparently, it looks like its Chinese only for now but hopefully this will be translated soon.Ahh this a shame. Do you have any plans to open up the new app for Gen 1 customers? Hope so![]()
ok thanks. So as I understand correctly, all 3 apps above will work with the Roamer Gen 1 battery , but the Xiaoxiang App is the Roamer preferred app to use with the Gen 1 battery ?Unfortunately not, it only works with the VIP BMS... We'd need to create an entirely new app to work with the Jaibaida BMS. Its a massive investment in time and money so while I'd love to do this to support existing customers, it's just not an option right now. There are a lot of decent apps to use with JBD BMS however as its used in a lot of other LiFePO4 batteries such as Liontron and AOLithium (this one is probably the best of the lot). There is also a second version of Xiaoxiang BMS on the way apparently, it looks like its Chinese only for now but hopefully this will be translated soon.
Correct. JBD is a very popular BMS so there are lots of apps out there but the official (and recommended) option is Xiaoxiang BMS. If you need any more support with the Gen 1 battery please drop me an email and I'll pick up as a support ticketok thanks. So as I understand correctly, all 3 apps above will work with the Roamer Gen 1 battery , but the Xiaoxiang App is the Roamer preferred app to use with the Gen 1 battery ?
