-- ROAMER 230SB3 (Gen3) --
its finally here, -
the latest Gen3 version of the Roamer - SeatBase 230Ah Lifepo4 battery.
Roamer SMART4, XTREME and HOME - the next generation in 12v 24V and 48V LiFePO4 lithium leisure batteries for campervans, motorhomes and boats. From 100Ah to 460Ah capacity with Bluetooth BMS, Victron GX integration, Active Balancing and low temperature charge protection. 5 Star UK support, 10...
roamer.com
now with a spec and test sheet, QR code for the cell pack. . . stickers and more.
there is a new sticker on the top with all the important details,
and QR code for the APP,
its the same APP as before. . .
I've been full testing it over the last few weeks. . .
we built a portable battery box . . .
that run T6F Summer camp . . .
4173Wh (330Ah) Lithium Battery Box -- How I Done It -- its that time again. . . battery box build time. but this time i need MORE POWER, were off camping for a 4/5dayer at the racing track - But the weather is not looking so good. that means Solar will be poor for the recharge. . . . . and...
www.t6forum.com
we pulled it apart and tested every element of it. . .
The New SMART Range of Roamer battery's gets the @Dellmassive thumbs up and seal of approval.
well done guys.
roamer.com
so what's new . . . .
new active cell balancer,
can run a 3000w inverter,
250A / 500A discharge rate,
same 10year warranty.
230SEATBASE3
12V 230Ah LiFePO4
The bar has been raised yet again. Say hello to our 3rd generation Roamer 230SEATBASE3. Grade A+ matched cells provide 230Ah of usable capacity while a high power Battery Management System (BMS) with Active Balancing allows up to 3200W of continuous power - all in a custom case that fits neatly under a campervan swivel seat.
Active Balancing
Our premium active balancing module is a first in the UK market. Keep your battery cells finely balanced with no energy losses, access the full available capacity, and extend the useful life of your battery. Cell balancing is an essential feature of every Battery Management System (BMS) but most BMS use passive balancing as its simpler and cheaper. Active balancing involves moving charge from one cell to another rather than simply burning off the excess charge through a resistor, making it more efficient and able to balance cells even when the battery is discharging. With a balancing current of up to 2000mA compared to the typical 50mA found on other BMS, the new Roamer SMART battery can also handle a wider range of charge voltages and is less prone to cell voltage drift that can develop as a result of incorrect charging.
Serviceable. Repairable. Upgradeable
As part of our journey towards a more sustainable model and to underline our commitment to sustainability, we designed our new SMART batteries to be fully serviceable, repairable and upgradeable. Combined with free ROAMERCARE you get complete peace of mind that your battery will live a long and happy life. ROAMERCARE offers service guarantees for the life of your battery but also provides the opportunity to upgrade at any point so you don’t need to worry about missing out on future BMS developments - our modular design allows for simple repairs and BMS swaps. It’s so simple, you could even do it yourself on the road.
Built by adventurers with a genuine passion for van life
The Roamer 230SEATBASE3 uses the very best Grade A+ matched cells and comes assembled with precision-engineered brackets, laser-welded cell connections, flexible copper busbars and an IP65 waterproof case.
Maintaining excellent balance throughout its 15 year life expectancy, your Roamer will deliver stable, high power with every cycle. Our additional factory and warehouse testing processes ensure the highest possible quality and because we believe in our product, we back everything with a 10 year warranty.
To ensure maximum lifespan, every 230SEATBASE3 comes with a state-of-the-art internal Battery Management System (BMS) with Active Balancing - developed specifically for Roamer to support high power off-grid living.
A front row seat to uninterrupted adventure
The 230SEATBASE3 is the newest version of our original low-profile LiFePO4 battery - designed for installation under a campervan swivel seat. We’ve used the same A+ grade matched cells and high-power BMS as our flagship 460 SMART3, allowing us to fit massive amounts of capacity into a case that is actually smaller than the previous model. With a continuous charge/discharge rate of 250A, you can power any domestic appliance up to 3200W via an inverter.
The upgraded BMS actively balances all internal cells, and also supports installation of multiple 230SEATBASE3 batteries in series or parallel - with auto balancing for parallel connected batteries. It provides a complete range of protections including low temperature charging.
With great power comes great responsibility
Roamer exists because we wanted the very best batteries for our own off-grid adventures. In our relentless pursuit of building the best, each and every battery is rigorously tested and checked before we ship it to you. Inside the box you’ll find our quality guarantee sticker and factory test certificate. We also do everything humanly possible to ensure that our batteries are manufactured, tested, distributed, and delivered in the most environmentally sustainable way possible. Our batteries are also built to be serviced, repaired or upgraded as required, thereby reducing waste and maximising the life of raw materials used.
Safety First
Here at Roamer, we take safety extremely seriously and strive to make the safest LiFePO4 batteries possible. It is no secret that Lithium can be dangerous and whilst LiFePo4 is without doubt, the safest option, it is still not without risk. And that’s why we go above and beyond on both compulsory and voluntary extensive safety tests and processes. We choose to test every single battery before it leaves the factory by cycling to 100% and 0% and applying a high charge and discharge load to identify potentially faulty cells and connections, test BMS performance and verify cell balance at the top and bottom of the voltage-charge cycle. Our SMART3 batteries use only traceable branded cells from reputable manufacturers with lab test reports to verify battery safety as part of the EN 61619 certification. Finally, our product and fulfilment services also meet the courier requirements to ship Dangerous Goods under the UN3480 certification. Find out more about the steps we have taken to ensure maximum safety here.
New user guide:
I've now fitted the 230SB3 in the T6, . . .
the Gen2 230SB is now in the battery box for portable power.
with both of these battery's i can now call upon 460Ah worth of Lifepo4 power.
that should see us through . . . . . .
check em out . . .
roamer.com
Roamer on T6Forum -
@RoamerBatteries
