Thanks for posting your install pics.... great to see people working out smart ways to use our batteries! The Redarc BCDC is really compact too so thats a neat way to get solar and DCDC charging in the space. I'm about to press go on the designs for the third generation version of the seatbase battery so would be very helpful to get some feedback.... is there anything you would change about the design?
We're going to use 230Ah CATL cells on next model, which are a lot more compact. This means we can increase the capacity by 15% and also make room for a bigger Bluetooth BMS (250A continuous discharge) and still reduce the overall size. Unfortunately we cant get it any smaller widthways which from your photos looks like a useful space. We have managed to trip 3cm from the length however.... so its now 305mm x 290mm x 180mm.
We've had to swap the recessed handles for surface mounted ones, hopefully there is still plenty of headroom above the battery at the midpoint? It would be possible to remove the handles after installing if it was an issue but this isn't ideal, I'd probably relocate them to another part of the battery if so.
We have stock of 2nd gen 200Ah batteries due at end of September by the way. These are £950 plus £50 delivery (£855 plus £50 with 10% preorder discount). The 3rd gen 230Ah batteries will arrive at end of November, and will be a bit more expensive at £1150 but will now include free delivery anywhere in mainland UK.
