Hi – Some updates to my Valence install (under single passenger seat). I had originally written a fairly in-depth walk through of my steps for this, but tried to save it as a draft halfway through and it failed to recover when I came back to it. I'll be dammed if I'm typing it all out again, so here's a slimmed down version...
To secure mine under the seat, I've used two 'braces' in front and behind the battery, then secured with 2x battery retaining straps.
The braces are made from aluminium angle lengths – readily available from DIY stores, or in my case, recycled from the step edges of my van's factory ply lining.
The black areas are self adhesive rubber strips I purchased from eBay – mainly to help grip the battery and minimise vibration, etc. It's about 3mm thick...
In order to maximise the height above the battery – allowing optimum airflow and clearance for my Sportscraft swivel, I wanted the battery to sit as low as possible within the base.
To achieve this, and provide a more solid fixing surface for my battery braces, I used an angle grinder to remove the lipped edges – found near the four main bolts for the seat base. This also got rid of the bloody sharp edges that I seamed to lacerate my hands on every time I went near them.
Cleaned-up and re-sprayed with some satin black Hammerite...
Here's the braces bolted onto the seat base:
Note – the battery only sits on the brace behind the battery, with the front one acting as a 'stop' – preventing the battery from moving forward...
Most of the battery weight is actually supported by the van floor – If you look closely, you can see that I've notched-out a section on both sides, just in front of the front brace – allowing the battery to rest on the rubber matting of the van floor. Again, this was in the interests of allowing as much space as possible above it.
I added two small adjustable angle brackets either side of the base to act as side stops, preventing side-to-side movement of the battery when in transit.
Again, some self adhesive rubber was added to these for surface protection/grip.
You can also see the two buckled, retaining straps in the image below:
I then made a mount for my battery kill switch – to be attached to the front brace – again, this was made using the aluminium angle strip.
On the side, I attached my main loads out fuse holder, just before the Victron battery protect.
Here's a shot with the battery in place and secured with the straps... My DC/DC charger isn't mounted in this image, but that attaches to the front end of the seat base... you can see the bolts sticking out below.
That's it for now, hope this may help others looking for a similar solution
