I’m just as confused as you
@andys...
What I don’t get is that, any bridge between the L and H pin means the charger is ‘on’ - regardless if any voltage is being applied to it. If we apply >7v to the L pin as stated in the manual, then great, we bypass the engine detection and force the charger to run, but by bridging to the H pin, surely this means that with the ignition off, the unit will remain on and revert back to engine detection mode?
I’m wondering if the best option is to wire the ignition feed to the H-pin only which has an ‘on’ signal when >3v is applied? A single, inline switch could be used as a master on/off. However, although the charger would turn on with the ignition using this set-up, it would still be engine detection mode.
